Needle properties define the shape, size, and color of a needle. A needle appears only in a linear gauge and in a meter gauge, and is used to point to a data value. Figure 17-7 shows the needle properties set for a meter gauge.For a meter gauge, the needles properties apply only to the pointer part of the needle. To format the base, or pivot, of the needle (represented by the circle), choose Needle Base/Pivot.Table 17-3 shows all the needle properties and lists the gadgets to which they apply.
Table 17-3 Sets the size of the bottom part of the needle, as a percent of the size of the gadget. Linear gauge, meter Linear gauge, meter Fill Background Color Sets the size of the portion of the needle behind the pivot as a percent of the size of the gadget. Enables or disables the display of the value to which the needle points. Linear gauge, meter Sets the size in pixels, or in percent of gadget width, of the needle. Linear Gauge, meter Sets the size of the tip of the needle as a percent of the size of the gadget. Linear gauge, meter Sets which needle to format. Several needles can co-exist, based on the data used to create the gadget. Value Textbox X Co-ordinate Sets the x coordinate of the value text, as a percent of gadget width. Value Textbox Y Co-ordinate Sets the y coordinate of the value text, as a percent of gadget height.
