Number formatting properties define how numbers are displayed in a gadget. Use these properties to abbreviate numbers, to add text before or after a number, or to specify the number of digits to display after a decimal point.
Figure 17-9 shows the number formatting properties set for a thermometer gauge. Numbers display with the dollar symbol ($) before the number and they appear in abbreviated format, such as $30K instead of $30,000.
Table 17-5 shows all the number formatting properties. These properties are used in all the gadgets.
