Tick properties define the size, color, and position of tick marks on a gadget. Figure 17-13 shows the tick properties set for a linear gauge. Tick marks appear at the top and inside the gauge. The first and last tick values display Min and Max instead of numbers.Table 17-7 shows all the tick properties and lists the gadgets to which they apply.
