The Flash object library provides all the common gadgets—linear, meter, bullet, cylinder, and thermometer—supported by the built-in Flash gadget element, and many others, including funnel, pyramid, gantt, and LED gadgets. Gadgets, commonly used in dashboard applications, are suitable for displaying KPIs (Key Performance Indicators) and other critical data that are monitored in real time.
Figure 18-2 shows examples of Flash gadgets that are available in the library, but not in the Flash gadget element in the palette.
