Task 7: In this procedure, create a Java class that contains the code to generate the XML data required by the Flash chart. This class implements the data extraction interface, IDataExtractionExtension.
4 In Implemented Interfaces Selection, select IDataExtractionExtension. If the dialog box does not display any interfaces, do the following:
5 Use the default values for the other options. Figure 18-31 shows the properties for the class.
Figure 18-31
6 Choose Finish. In Package Explorer, the class, XMLGenerator.java, appears in the plug-in’s src folder. The content of XMLGenerator.java appears in the editor, as shown in Figure 18-32.
Figure 18-32
