Task 9: In this procedure, deploy the plug-in using Eclipse’s Export utility. This utility creates a plug-in JAR file and copies it to a specified folder.
1 From the main menu, choose File→Export.
2 In Export, expand Plug-in Development, and select Deployable plug-ins and fragments, as shown in Figure 18-33.
Figure 18-33
3 Choose Next. In Export, Available Plug-ins and Fragments displays the plug-in you created.
