Task 6: Map the data set values to the Flash map entity valuesTo display data from the data set in the Flash map, you need to map the territory values in the data set to the internal ID values used by World Map.Each case statement replaces a territory value with the corresponding internal ID used by the map.
4 Choose Preview Results. The data set returns the data shown in Figure 18-16. The Territory_ID values match Internal Id values in World Map.
