HTML reports display Flash content. Report users must have Flash Player installed. PDF reports can also display Flash content if the Adobe Reader supports Flash. Download a version of Adobe Reader that supports Flash from the following location:
If creating a report that contains Flash content and that will be viewed in other formats, such as XLS or DOC, use the visibility property to hide Flash objects in formats that do not support Flash. If you do not hide the Flash objects, the report displays a message, such as “Flash report items are not supported in this report format.” As a substitute for a Flash chart or gadget, use a standard chart or an HTML5 chart and set it to appear in formats that do not support Flash content.
