1 In Name, type a unique name for the variable. JavaScript event handlers use the name to access the variable’s information through dataObject. For example, the event handler accesses a variable named credit as dataObject.credit.
2 In Expression, type the value that the variable contains. You can also use Expression Builder to create a value. Choose OK.
Figure 22-12
