As mentioned previously, HTML buttons are supported in HTML reports only. To test the functionality of an HTML button, run the report in the web viewer. The previewer in the report editor does not support the Actuate JavaScript API. You can view an HTML button that contains JSAPI code in the previewer, but it does not respond to any button events.
