On the Select Chart Type page, Theme displays the theme currently applied to the chart, or None, if one is not applied. To change the theme or apply one, select a theme from the drop-down list. The list displays all the predefined themes, as well as, the themes that you created. When you select a theme, the chart previewer shows the changes instantly.
