As mentioned earlier, Actuate BIRT Designer uses Highcharts, a third-party charting library, to render HTML5 charts. To create a JavaScript chart theme, you set the Highcharts chart options to values that provide the visual attributes you desire. Every option has a default value. You define attributes only to change default settings, or to add items that do not appear by default.
Listing 15-1 shows the JavaScript code for the predefined chart theme, Chart Grid. The charts in
Figure 15-2 and
Figure 15-3 use this theme. As the code shows, options are set using a JavaScript object notation structure. Keys and values are connected by colons, separated by commas, and grouped by curly brackets.
The Highcharts reference contains two sections, The options object and Methods and properties. Look at The options object for information about the options you can set in a chart theme.
