The procedure for creating an HTML5 chart is the same as the procedure for creating a BIRT chart. To create an HTML5 chart, perform the following tasks:
In the chart builder, choose a chart type, and set Output Format to HTML5, as shown in Figure 15-1. This is the default format if you select a chart type supported by HTML5.This chapter describes the features that are unique to HTML5 charts, for example, scripting with the Highcharts API and designing chart themes using JavaScript. For information about the different chart types, specifying data for a chart, and using the standard formatting options, see BIRT: A Field Guide.
Figure 15-1
