A BIRT report uses scripts to implement custom functionality. For example, you can use scripts to create a scripted data set or to provide custom processing for a report element. When you deploy a BIRT report to an Encyclopedia volume, you must provide iServer with access to the Java classes that the scripts reference. You package these classes as JAR files that can be recognized and processed from an iServer Java factory process. There are two ways to deploy Java classes:This method supports creating specific implementations for each volume in iServer. This method of deployment requires packaging the Java classes as a JAR file and attaching the JAR file as a resource to the report design file. You treat a JAR file as a resource in the same way as a library or image. Using this method, you publish the JAR file to iServer every time you make a change in the Java classes.This method uses the same implementation for all volumes in iServer. Actuate does not recommend deploying JAR files to an iServer /resources folder because iServer must be restarted after deploying the JAR file. Another disadvantage of this deployment technique is that the JAR file, deployed in the iServer /resources directory is shared across all volumes, which can cause conflicts if you need to have different implementations for different volumes. When using this method, you do not have to add the JAR file to the report design’s Resource property.
