1 Package the Java classes as a JAR file and copy the JAR file to the Actuate BIRT Designer resource folder.
3 In Outline, select the root report design slot and select Resources property group in the Property Editor window.
4 In Resources, in JAR files, choose Add and navigate through the Resource folder to select the JAR file, as shown on Figure 26-6.
Figure 26-6 When the report executes, the engine searches for the required classes and methods only in this JAR file.
5
2 Select Publish Report Designs, choose the report, and the folder on iServer where you want to copy the report.
3 Select Publish Resources and choose the JAR file. The JAR file is stored in the Encyclopedia volume’s Resource folder.
