You can publish BIRT resources from the BIRT Report Designer’s local resource folder to iServer. By default, the Resource folder is the current report project folder. If you use shared resources with other developers and the resource files for your reports are stored in a different folder, you can change the default Resource folder. Use Windows
→Preferences
→Report Design
→Resource menu to set the resource folder.
In the Encyclopedia volume, the Resource folder is set to /Resources by default. In the sample Encyclopedia volume, the /Public folder contains sample reports. The libraries and templates used by these sample reports are stored in the /Resources folder.
If the resource folder in the Encyclopedia volume is different from the default, before publishing a resource, you need to set up the Resource folder in the Encyclopedia volume.
