For ACLs to take effect, you must enable data security in the data object. If you decide later to make all the data in the data object available to users, all you do is disable data security. You do not have to remove the ACLs.
1
2 In Security, shown in Figure 23-27, either select or deselect Enable Data Security.
Figure 23-27
