For ACLs to take effect when the report is run on iServer, you must enable page-level security in the report design. When enabled, BIRT generates a report that consists of pages, which are restricted to users with specified security IDs. If you decide later to make the entire report available to users, all you do is disable the page-level security option. You do not have to remove the ACLs.
2 In Security, shown in Figure 23-7, either select or deselect Enable Page Level Security on generated report document.
Figure 23-7
