A linear gauge is a slider gauge with many additional features. It uses a horizontal scale to display your data range and fully configured data needles to indicate data values.You can convert linear gauge gadgets into meter gadgets. The example in Figure 8-42 uses a linear gauge to illustrate the amount for resolved orders.
Figure 8-42
