A cylinder gauge is represented by a vertical cylinder, whose fill level is indicative of the data to be displayed. It is used to show inventory levels, power plant reports, and fuel levels. The example in Figure 8-43 uses a cylinder gadget to illustrate the amount for orders that are on hold.
Figure 8-43 You can convert cylinder gadgets into thermometer or bullet gadgets, as described later in this document.
