A bullet gadget is a variation of a bar chart and serves as a replacement for dashboard gauges and meters, which typically require too much space, and are cluttered with distracting decoration. There are horizontal and vertical bullet gadgets. The example in Figure 8-45, shows a horizontal bullet gadget, illustrating the amount for orders in progress.
Figure 8-45 You can convert bullet gadgets into cylinder gadgets or thermometer gadgets, as described in this document.
