You can format data in Flash charts in the same way that you format data in a standard chart. You can modify the font used for the chart title, the axes, the legend, and the tooltip of a chart. The font used for the tooltip is called the base font. The font used for the chart title, axis labels, and legend is known as outside font. You can specify the font type, size and color for base fonts and outside fonts.To format a Flash chart, select the chart. Then, choose Format Chart from the chart menu and modify the information on Format as needed. Choose OK.
