Each gadget has a different set of formatting properties, which change specific aspects of the gadget’s appearance. Figure 8-49 displays the formatting options you can modify in a linear gadget. Figure 8-50 and Figure 8-51 display the Format Flash Gadget dialog box for the linear gadget.
Figure 8-51 For each Flash gadget you can modify a set of general formatting options, as well as needle, plot, scale, region, tick marks, and value properties.
