Needle properties define the position of a needle. A needle appears only in a linear gauge and in a meter gauge. Table 8-2 describes the needle properties you can modify in Interactive Viewer.
Table 8-2 Show Needle On Show Needle Value Displays or suppresses the value to which the needle points, and specifies the display position for the values
