Region properties enable the division of the data plot into regions. Use regions to provide more information about values in a gadget. Table 8-5 describes the region formatting properties you can modify in Interactive Viewer.
Table 8-5 Linear gauge, meter, bullet Linear gauge, meter, bullet Linear gauge, meter, bullet Linear gauge, meter, bullet Chooses the region for which the settings apply. You can also add or remove a region from the list. Linear gauge, meter, bullet Displays or suppresses the region labels.
