You can also display or hide the value in a cylinder or thermometer gadget, as described in Table 8-7.
Table 8-7 Displays or hides the value illustrated in the gadgetTo format a Flash gadget, select the gadget. Select Format Flash Gadget from the gadget menu and modify the information on Format as needed.
