Filtering data in a Flash chart or gadget
You can also create filters for chart and gadget data in the same way you do for standard charts. You can limit the appearance of data on a chart or gadget by setting filters for the chart or gadget data.
How to filter data in a Flash chart or gadget
Select the chart or gadget, and choose Filter from the chart or gadget menu. Create conditions as needed. To define more than one condition, choose Advanced Filter and modify the options in the same way you did when creating filters for report data.
Additional Links:
