In Actuate 11 and later releases, you can export data from a Flash chart or gadget to a flat file format, which uses a comma, tab, pipe, or semicolon delimiter. These file formats can be read by Microsoft Excel.Select the chart or the gadget, and choose Export Data from the chart or gadget menu. On Export Data, specify the data to export, and other options, in the same way you did when exporting report data.
