The formatting options available for an HTML5 chart are similar to those available for standard charts. For a bar, column, line, or area chart, the formatting options available for HTML5 charts are the same as the options you use to format standard charts, except that you cannot set the dimension for HTML5 versions of these chart types. For pie and doughnut charts you can modify the chart title, and specify the width and height.
