You can also create filters for HTML5 chart data in the same way you do for standard charts. You can limit the appearance of data on a chart by setting filters for the chart data.Select the chart, and choose Filter from the chart menu. Create conditions as needed. To define more than one condition, choose Advanced Filter and modify the options in the same way you did when creating filters for report data.
