Using Interactive Viewer, you can export an HTML5 chart to all other supported formats, but the chart displays as a static image. The chart is identical in appearance to the chart displayed in the viewer.Select the chart, and choose Export content from the chart menu. On Export Content, specify the options in the same way you did when exporting report content. Additionally, specify the resolution in DPI at which to export the chart.
