Changing font properties and alignment
Using Interactive Viewer, you can change the font properties and alignment of values in cross-tab elements, including dimension and measure labels and data values. The properties you can modify include the background color, font color, size, and type. A value of Auto indicates that the default value applies. You can also specify whether to display the font in bold, italic, or underlined style.
How to change font properties
1
Select a cross-tab element. From the main menu, choose FormatFont.
Font displays the current font property values, as shown in Figure 9-2.
2
Use the drop-down lists to modify the font properties for the selected element.
Choose OK.
Figure 9-2
How to change text alignment
Select a cross-tab element. From the context menu, choose AlignmentLeft, AlignmentCenter, or AlignmentRight.
Additional Links:
