Reverting to default formats
To revert a cross-tab element back to its default font formats, select the cross-tab element. From the main menu, choose Format→Font. Select Auto from each drop-down list. To reset text alignment, select the element, and choose the appropriate alignment option.
If you applied a number format to data, you can restore the formats to those in the original cross tab. Select the data cell. From the context menu choose Format→Format Data. Then, select Unformatted from the drop-down list.
Additional Links:
