Analyzing cross-tab dataYou can use BIRT Data Analyzer to manipulate a cross tab to analyze its data. Using BIRT Data Analyzer, you can answer questions such as:You can add, remove, reorganize, and customize the data and its appearance in the cross tab to examine relationships and trends. Using BIRT Data Analyzer, you can perform the following tasks:To launch BIRT Data Analyzer, select any cell in the cross tab, then from the menu, choose Data Analyzer.For more information about BIRT Data Analyzer, see Using BIRT Data Analyzer.
