How to export a report or report element to AFP format
1
To export a report, or report element, such as a cross tab, or a chart, choose Export Content from the main menu, as shown in Figure 4-3. Export Content appears.
Figure 4-3
On Export Content, in Export Format, select Advanced Function Printing (AFP) from the list, as shown in Figure 4-4.
2
If you do not specify a value in this field, the BIRT Viewers export all the pages in the current report design. If you are exporting a report component, leaving this field blank exports only the selected component.
If exporting a chart, specify the export resolution DPI. If you do not specify a value, the BIRT Viewers export the chart using the value 192 DPI.
Select an option from the list. if you do not specify a value, the BIRT Viewers use the value 240 DPI.
Specify one of the following plex modes for the exported file:
Choose OK.
Figure 4-4
3
Figure 4-5
Choose Open or Save.
When you open the file, the content is displayed in your web browser using the AFP Viewer plug-in, with the options you specified, as shown in Figure 4-6.
Figure 4-6
Additional Links:
