6 If exporting a chart, specify the export DPI. If you do not specify a value, the BIRT Viewers export the chart at 192 DPI.
7 Select Fit to Paper to enable the PostScript emitter to format the report according to the size of the paper in use.
4 File Download appears. The default name assigned to the file and file extension are visible. Choose Open or Save.
