The following example calculates and displays different discount amounts based on the value in the Total data field. If the Total value is greater than 5000, the discount is 15%. Otherwise, the discount is 10%.
The following example uses IF( ) in conjunction with the BETWEEN( ) and ADD_DAY( ) functions to calculate a shipment date. If an orderDate value is in December 2007 (between 12/1/07 and 12/31/07), add 5 days to the orderDate value. If a orderDate value is in a month other than December, add 3 days to the orderDate value.
The following example checks each value in the Office data field. If the value is Boston, San Francisco, or NYC, the computed column displays U.S. If the value is something other than Boston, San Francisco, or NYC, the computed column displays Europe and Asia Pacific.
