NOTNULL( )The data field in which to check for non-null values.The following example uses NOTNULL( ) in conjunction with the IF( ) function to test for non-null values in the BirthDate data field. If there is a non-null value, the BirthDate value is displayed; otherwise the string “No date specified” is displayed.
