SQRT( )The number, or numeric expression specifying the number, for which you want to find the square root. The number must be a positive number.The following example uses SQRT( ) to calculate the actual distance travelled uphill, given the base distance and elevation values. This example applies the Pythagoras theorem, which states that . Using this theorem, the actual distance travelled is c, which means we want to calculate
