TRIM( )Removes the leading and trailing blanks from a specified string. TRIM( ) does not remove blank characters between words.The following example uses TRIM( ) to remove all leading and trailing blank characters from values in the FirstName and LastName data fields. The expression uses the & operator to concatenate each trimmed FirstName value with a space, then with each trimmed LastName value.
