Specifying page breaks
Using Interactive Viewer, you can set page breaks after a preset number of rows in a data column and you can start each group on a new page by specifying a page break before or after grouped data.
How to set and remove a page break on a report column
1
2
Figure 5-24
3
How to set and remove a page break on a grouped column
1
Select a grouped column. From the context menu, choose GroupPage Break. Page Break appears, as shown in Figure 5-25.
Figure 5-25
2
3
Additional Links:
