In Interactive Viewer, you can modify summary tables by editing and formatting data, creating filters to display specific data, inserting calculations in a summary table, and so on. Table 10-1 compares the actions you can perform on dimension columns, attribute columns, and measure columns.
Dimension column Attribute column Measure column Filter data using the Top/Bottom N condition. Sort column data in ascending or descending order.
