Filtering data in a summary table
You can filter data in dimension, attribute, and measure columns in the same way in which you filter data in a report table. You can create multiple filter conditions, and modify existing filter conditions. You cannot create filters for data in a dimension column containing date-and-time data.
You can also filter a measure column using the Top/Bottom N condition, as shown in Figure 10-3. Select the measure column, and choose FilterFilter or FilterTop/Bottom N from the context menu. You cannot use the Top/Bottom N condition to filter data values in a dimension or attribute column.
Figure 10-3
Additional Links:
