How to create an effect
1
2
Figure 17-25
3
4
5
In Add New Effect, type a name for the effect, then choose OK. Effect, shown in Figure 17-26, lists the types of effects that you can apply. Animation is selected by default.
Figure 17-26
6
7
8
9
Figure 17-27
My List shows an effect named Animate Labels. The check mark indicates that the effect applies to X-Axis Labels. The symbol under Animation and Font indicates that the Animate Labels effect uses animation and font effects.
For specific examples of creating effects, see the tutorials later in this chapter.
Additional Links:
Copyright OpenText Corporation 2017
