You can filter chart data in the same way that you apply filters to data in any report column. In a chart you can filter data on the x-axis or the y-axis. Select the chart, then choose Filter from the context menu. Chart Filter appears, as shown in Figure 8-24. Complete the steps to apply filters that define what data is displayed on the axes of the chart.
Figure 8-24
BIRT iHub 2 |
