Using effects In some types of Flash charts, you can use the context menu to set or modify visual animation effects. For example, in a pie or doughnut chart, you can specify the following properties: Enable rotation of the pie or doughnut. This option causes the pie or doughnut to rotate. Enable slicing movement. This option causes each segment of the pie or doughnut to appear to slice away from the original chart.
© Copyright OpenText Corp. All rights reserved. Privacy Policy | Cookie Policy
