Exporting data from an HTML5 chart You can export data from an HTML5 chart to a flat file format, which uses a comma, tab, pipe, or semicolon delimiter. These file formats can be read by Microsoft Excel. How to export data from an HTML5 chart Select the chart and choose Export Data from the chart menu. On Export Data, specify the data to export, and other options, in the same way you did when exporting report data.
© Copyright OpenText Corp. All rights reserved. Privacy Policy | Cookie Policy
