You can change a chart’s width and height. If a chart looks too big, you can reduce its width, height, or both. For example, a pie chart that displays few sectors can look oversized. Conversely, increase the size of a chart if items in the chart look too crowded. For example, if a column chart displays many columns, and many of the x-axis labels do not appear, you can start by increasing the width of the chart to see if all the items fit.
BIRT iHub 2 |
