You can change the font, size, and color for text that appears in the chart, including axis labels, axis values, chart title, legend items, x-axis title, and y-axis title. The default setting for font, size, and color is Auto, which enables Data Analyzer to apply the font, size, and color settings from a theme, if you select one. If you select a settings different from Auto, the settings you select apply.
BIRT iHub 2 |
