Setting x-axis labels angleYou can display labels at an angle by specifying the number of degrees. In Chart Builder—Format, in Labels Angle, select a value, or type the number of degrees to specify the angle. To rotate labels in a clockwise direction, use a negative number. To rotate labels in a counterclockwise direction, use a positive number. Figure 6-31 shows four charts, each with Labels Angle set to a different value.
BIRT iHub 2 |
